The HyperCrash Model Manager database file (B00 file) is composed of a RADIOSS input deck (D00 file – 41 Block Format) and at the bottom of this file, some information is necessary for HyperCrash.
The specific part of the B00 file starts with the keyword line:
/MODMNG/START
Some comments can be added between these lines. These comments will be displayed in the message window when the B00 file is loaded.
These lines must start with the # character.
/MODMNG/START
# This model will be merged with this model
All information that are in the M00 files are included in the B00 file between the two following keyword lines.
/MODMNG/MCRASH/START
spotwelds information
bolts information
tree information
/MODMNG/MCRASH/END
This keyword line is used to define a main direction for a model. This information will be used during the loading of the file for the automatic positioning.
/MODMNG/POSITIONING/DIRECTION
#--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---|
x-coordinate y-coordinate z-coordinate
1.0 0.0 0.0
/MODMNG/START
# Rigid Wall at x = 0
/MODMNG/HyperCrash/START
/MODMNG/HyperCrash/END
1.0 0.0 0.0
/MODMNG/END
# END OF MODMNG SPECIFIC INSTRUCTIONS
| Note: | Further information for the automatic positioning is defined in the Loadcase file description. |
The specific part of the B00 file ends with the keyword line:
/MODMNG/END
Where: |
Type |
Unit |
is a keyword |
Keyword |
No |
is a keyword to finish the input. |
Keyword |
No |
