The file, $MCRASHDIR/modmng/database_main.tbl defines the path of the different databases:
Two types of databases may be defined:
| • | Private database: just for the user |
| • | Public database: for any user |
This card defines the type of database and their path:
/MODMNG/DATABASE/type
<full_path>database_name_table.tbl
Where: |
Type |
Unit |
is a keyword |
Keyword |
No |
is a keyword |
Keyword |
No |
is a keyword which define the type of database:
Keyword |
No |
is the file name (with the full path) of the database table list of each databases |
String |
No |
Several database table can be defined under this keyword line.
/END
Where: |
Type |
Unit |
Keyword to finish the input. |
Keyword |
No |
/MODMNG/DATABASE/PRIVATE $HOME/private_database/private_database_1.tbl $HOME/private_database/private_database_2.tbl /MODMNG/DATABASE/PUBLIC $MCRASHDIR/database/database1.tbl $MCRASHDIR/database/database2.tbl $MCRASHDIR/database/database3.tbl /END |
For each database, there is only one table file (.tbl). This file defines all the sub-models (B00 files) located in the database.
For all the details about the sub-models (file B00), please refer to the B00 Description manual.
/MODMNG/DATABASE/DIRECTORY
directory_path
Where: |
Type |
Unit |
is a keyword |
Keyword |
No |
is a keyword |
Keyword |
No |
is a keyword |
Keyword |
No |
is the default directory path where the sub-model (B00 file) will be stored |
String |
No |
/MODMNG/DATABASE/MODEL
/path/File_name
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
9 |
10 |
Key_1 |
Key_2 |
Where: |
Type |
Unit |
is a keyword |
Keyword |
No |
is a keyword |
Keyword |
No |
is a keyword |
Keyword |
No |
is the file name of the B00 sub-model defined with its full path and/or with the variable, $MCRASHDIR. |
String |
No |
is the keyword list used to defined the model. The keywords are defined in the file, $MCRASHDIR/modmng/keyword.tbl |
String |
No |
To write a keyword with more than 8 characters, the character ’@’ will be set at the first position of the next field (See the section Keyword).
/END
Where: |
Type |
Unit |
Keyword |
No |
/MODMNG/DATABASE/DIRECTORY $MCRASHDIR/database/ /MODMNG/DATABASE/MODEL $MCRASHDIR/database/MODEL01B00 WINDSHIE@LD FEM FRONT $MCRASHDIR/database/MODEL02B00 ENGINE FEM FRONT /END |
