The model will be located in the database with a keyword list that will be used to research the model in the database.
All the keyword are defined in the file, $MCRASHDIR/modmng/keyword.tbl.
Several keyword lists can be defined in the keyword.tbl file. Each keyword list is defined inside a keyword group.
/MODMNG/KEYWORD
keyword_group_name
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
9 |
10 |
Key_1 |
Key_2 |
Where: |
Type |
Unit |
is a keyword |
Keyword |
No |
is a keyword |
Keyword |
No |
is the name of the keyword group |
String |
No |
is the name of the keyword (8 characters only) |
String |
No |
To write a keyword with more than 8 characters, the character ’@’ will be set at the first position of the next field (See the keyword FUEL TANK in the Example below).
/END
Where: |
Type |
Unit |
Keyword to finish the input. |
Keyword |
No |
#--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---| /MODMNG/KEYWORD Component MOTOR DOOR TIRE ENGINE SEAT RADIATORFUEL TAN@K ODB #- #--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---| /MODMNG/KEYWORD Model Type FEM BEAM RBODY MASS #- #--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---| /MODMNG/KEYWORD Crash type FRONT REAR SIDE ALL /END |
