Assigned parts
| 1. | Select one of the stamping results from the list. |
| 2. | Click to load the stamping result and display it in the small graphic window. |
| 3. | Click and pick part(s) in the graphic window. When finished, answer the question in the Dialog menu bar with Yes or Cancel. |
or
Click
to include (a) part(s) by box selection:
| • | The default box is rectangular. |
| • | Use the SHIFT key to define a polygon box. |
or
Click
to include the part(s) selected in the tree.
| Note: | The selected parts are displayed in the second list window. There is one list selection for each stamping result. |
Modify the assigned parts
Click
to deselect the assigned part(s) and select a new one.
