/BOLT/Bolt_id/Bolt_name/Type
Where: |
Type |
Unit |
is a keyword |
Keyword |
No |
is the identifier number of the bolt |
Integer |
No |
is the name of the bolt |
String |
No |
is the flag of the bolt (Integer):
Integer |
No |
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
9 |
10 |
X_center |
Y_center |
Z_center |
Diameter |
Xdir |
Ydir |
Zdir |
L1 |
L2 |
Where: |
Type |
Unit |
is the global coordinate value of the geometrical center of the bolt. |
Real |
Length |
Real |
Length |
Real |
Length |
is the diameter of the bolt |
Real |
Length |
is the bolt direction vector coordinates along X |
Real |
Length |
is the bolt direction vector coordinates along Y |
Real |
Length |
is the bolt direction vector coordinates along Z |
Real |
Length |
is search distance in negative direction on the axle of the bolt |
Real |
Length |
is search distance in positive direction on the axle of the bolt |
Real |
Length |
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
9 |
10 |
Npart1 |
Part1_1 |
Part1_2 |
Part1_10 |
Where: |
Type |
Unit |
is the number of part in the set 1 |
Integer |
No |
are the identifier number of the part of the set 1 (10 parts per line). |
Integer |
No |
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
9 |
10 |
Npart2 |
Part2_1 |
Part2_2 |
Part2_10 |
Where: |
Type |
Unit |
is the number of part in the set 2 |
Integer |
No |
are the identifier number of the part of the set 2 (10 parts per line). |
Integer |
No |
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
9 |
10 |
< full path > prop_file_name |
Where: |
Type |
Unit |
is the full path and file name of the spring property of the bolt |
String |
No |
In case <full path> is not defined, the prop_file_name will be read in the directory, $MCRASHDIR/property. Variable (like $MCRASHDIR) can also be used to defined the path.
#--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---| /BOLT/2/Front subframe fixation/1 -678.822 -449.455 301.25 50.000000 .000000 .000000 1.00000 100.00000 120.00000 3 10 12 13 2 11 21 #--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---| /BOLT/2/Front subframe fixation/3 -678.822 -449.455 301.25 50.000000 .000000 .000000 1.00000 100.00000 120.00000 3 10 12 13 2 11 21 $MCRASHDIR/my_bolt/bolt_256.prop #--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---| |
