The first line of the .mcrash file will be:
#MCRASH_GLOBALFILE
Where: |
Type |
Unit |
is a keyword |
Keyword |
No |
This line will be followed by:
/MODEL/model_title
Where: |
Type |
Unit |
is a keyword |
Keyword |
No |
is a name of the model |
String |
No |
The hierarchy of the model will be described by the appropriate number of the following lines:
/TREE/ASSEMBLY/assembly_id/assembly_title
Where: |
Type |
Unit |
is a keyword |
Keyword |
No |
is a keyword |
Keyword |
No |
is the identifier number of the assembly |
Integer |
No |
is the name of the assembly |
String |
No |
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
9 |
10 |
Nbchild |
In the following lines we have Nbchild (Integer) representing IDs of Assemblies, Physical Parts, or Subparts.
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
9 |
10 |
Child1 |
Child10 |
Child_ Nbchild |
/TREE/HPART/hpart_id/NAME
Where: |
Type |
Unit |
is a keyword |
Keyword |
No |
is a keyword |
Keyword |
No |
is the identifier number of the HPART |
Integer |
No |
is the name of the HPART |
String |
No |
Note:
| • | It must be the same as the one defined in the corresponding .mesh file. |
| • | Two assemblies cannot share the same ID. |
| • | One assembly and one physical part cannot share the same ID. |
| • | Two physical parts cannot share the same ID. |
#--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---| /TREE/ASSEMBLY/6/SEAT_L_COMP 25 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 /TREE/HPART/7/STIFF_RR_LWRARM_L /TREE/HPART/8/MEMBER_ENG_CRADLE #--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---| |
For each physical part, we must have the following line in the file:
/MASS/part_id/mass_value/unit
Where: |
Type |
Unit |
is a keyword |
Keyword |
No |
is the identifier of the part (HPART or SUBPART) |
Integer |
No |
is the mass value of the HPART or SUBPART defined by part_id |
Real |
Mass |
is a keyword which defines the unit and can be:
String |
No |
#--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---| /MASS/1345/12.0567/hunit /MASS/1365/56.00/g /MASS/1/.0001/t #--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---| |
The total theoretical mass of the car must be given to the keyword:
/TOTALMASS/mass_value/unit
/FRONTMASS/mass_value/unit
/REARMASS/mass_value/unit
Where: |
Type |
Unit |
is a keyword |
Keyword |
No |
is a keyword |
Keyword |
No |
is a keyword |
Keyword |
No |
is the theoretical mass value |
Real |
Mass |
String |
No |
#--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---| /TOTALMASS/1650.0000/kg /FRONTMASS/800.0000/kg /REARMASS/850.0000/kg #--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---| |
The theoretical coordinates of the center of mass are to be defined by the following block:
/CENTERG/unit
Where: |
Type |
Unit |
is a keyword |
Keyword |
No |
is a keyword which defined the unit and can be:
String |
No |
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
9 |
10 |
Xg |
Yg |
Zg |
Where: |
Type |
Unit |
Are the coordinate values of the center of mass in the global coordinate system. |
Real |
Length |
Real |
Length |
Real |
Length |
End of input data is signalled with:
/END
Where: |
Type |
Unit |
Keyword to finish the input. |
Keyword |
No |
Go to
