/GLUE/glue_type/Nb_pt/Glue_id
Where: |
Type |
Unit |
is a keyword |
Keyword |
No |
is keyword which defined the glue type:
Keyword |
No |
is the number of geometrical points defining the surface glued |
Integer |
No |
is the identifier number of the glue |
Integer |
No |
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
9 |
10 |
Part_1 |
Part_2 |
Gap |
Property_name |
Where: |
Type |
Unit |
is the identifier number of the first part to weld |
Integer |
No |
is the identifier number of the second part to weld |
Integer |
No |
is the distance value to search the connection |
Real |
No |
is the file name of the springs property of the glue. The spring property file should be stored in the directory $HCRASHDIR/property (text). |
String |
No |
This card has to be defined only for type = LINE or AREA
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
9 |
10 |
X1_1 |
Y1_1 |
Z1_1 |
X2_1 |
Y2_1 |
Z2_1 |
X1_I |
Y1_I |
Z1_i |
X2_I |
Y2_I |
Z2_i |
X1_nbr_pt |
Y1_nbr_pt |
Z1_nbr_pt |
X2_nbr_pt |
Y2_nbr_pt |
Z2_nbr_pt |
Where: |
Type |
Unit |
Global Coordinates of points defining the position of the glue for both parts or subparts to weld: one Card for each point. |
Real |
Length |
Real |
Length |
Real |
Length |
#--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---| /GLUE/LINE/3/16 3 4 0.000000SPRI_13_Glue 25.271300 46.455500 0.000000 25.271300 46.455500 5.000000 35.271300 46.455500 0.000000 35.271300 46.455500 5.000000 45.271300 46.455500 0.000000 45.271300 46.455500 5.000000 /GLUE/AREA/4/17 3 4 0.000000SPRI_13_Glue 31.000000 62.000000 0.300000 31.000000 62.000000 7.000000 31.000000 47.000000 0.500000 31.000000 48.000000 8.000000 50.000000 34.000000 0.000000 50.000000 33.000000 7.000000 68.000000 56.000000 0.400000 68.000000 58.000000 7.000000 /GLUE/AUTO/0/18/automatic glue 3 4 20.00000SPRI_13_Glue #--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---| |
