| 1. | From the Menu Bar, select Imposed Velocity > Modify. |
| 2. | Select imposed velocities using one of the following options: |
Button |
Behavior |
select all the imposed velocities. |
pick the arrow for the imposed velocity in graphic window to select it. When finished, answer the question in the Dialog menu bar with Yes or Cancel. |
select imposed velocities by box (use the SHIFT key to use a polygon box). |
pick parts in the graphic window to select all the imposed velocities applied to those parts. When finished, answer the question in the Dialog menu bar with Yes or Cancel. |
select parts by box (use the SHIFT key to use a polygon box) to select all imposed velocities applied to those parts. |
Click the imposed velocity line in the listing window to select it. Several imposed velocities from this list can be selected using the SHIFT, CTRL, or SHIFT+CTRL keys. |
| 3. | Select only one imposed velocity and click |
| • | Change the imposed velocity name. |
| • | Select or deselect nodes or parts (see Node selection). |
| • | Modify the skew frame (see Reference axis). |
| • | Modify the sensor (see Sensor). |
| • | Modify the properties (see Properties setting). |
| • | Modify the imposed velocity direction (see Direction setting). |
| 4. | Click |
| 5. | Answer the question in the pop-up dialog window with Yes or Cancel. |
| 6. | Click Save to save the modified imposed velocity; or |
Click Cancel to cancel the imposed velocity modification.
| 7. | Click Close to close the menu. |
