»Click here to display Table of Contents« HyperCrash > HyperCrash User's Guide > LoadCase:
If you are working in the LS-DYNA profile, from the Menu Bar, select LoadCase > Imposed Velocity. Right-click in the Imposed Velocity panel to access boundary conditions options. Otherwise, the following instructions will guide you in each process.
