| 1. | From the Menu Bar, select Connections > Mig Weld > Criteria. |
A MIG Weld Criteria dialog opens.
| 2. | Select the appropriate criteria to check by clicking the appropriate check box. |
| 3. | Enter the desired values for each parameter (It is recommended to use the default values). |
| 4. | Validate in the pop-up dialog window with Save. |
| 5. | To reset to the default values, click Reset. |
