Note: | To accept selection(s), press Enter, click Yes or right-click the mouse button; or select Cancel. |
1. | From the Menu Bar, select Connections > Mig Weld > Modify. |
2. | Select only one Mig weld. |
3. | Click to display the Mig weld and to open the modification menu. |
• | In the Part sub-window: |
Button |
Behavior |
displays all the parts in the neighborhood of the selected Mig weld. |
pick parts in the graphic window to add them to the Mig weld definition. |
select parts by box in the graphic window to add them to the Mig weld definition. |
add the selected parts of the tree in the Mig weld definition |
deselects the parts that define the Mig weld. |
• | In the Location sub-window, it is possible to change the Mig weld location. |
4. | Click Save to save the modified Mig weld; or |
Click Cancel to cancel the Mig weld modification.
5. | Click Close to close the menu. |
Button |
Behavior |
selects all the Mig welds |
selects all the uncreated Mig welds |
pick Mig weld in graphic window to select them |
select Mig weld by box (use the SHIFT key to use a polygon box) |
pick parts in the graphic window to select all the Mig weld linked to those parts. |
select parts by box (use the SHIFT key to use a polygon box) to select all the Mig weld linked to those parts. |
Click on Mig weld in the listing window to select it. Several Mig welds from this list can be selected using the SHIFT, CTRL, or SHIFT+CTRL keys. |
automatically recreate the "uncreated" Mig weld. In the message window, a message explains why this Mig weld cannot be created |
