Results Mapper is able to read the user format defined as follows:
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
9 |
10 |
BEGIN BULK |
Where: |
Type |
Unit |
is a keyword to define the beginning of the data |
Keyword |
No |
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
9 |
10 |
GRID* |
Node_id |
x_coord |
y_coord |
cflag |
cflag |
z_coord |
Where: |
Type |
Unit |
is the keyword (double field format) |
Keyword |
No |
is the identifier number of the node |
Integer |
No |
are the coordinate values of the node in the global frame |
Integer |
No |
is the continuation line flag |
String |
No |
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
9 |
10 |
CQUAD4 |
EID |
PID |
Node_1 |
Node_2 |
Node_3 |
Node_4 |
cflag |
cflag |
TH_1 |
TH_2 |
TH_3 |
TH_4 |
Where: |
Type |
Unit |
is the keyword for the 4 nodes shell element |
Keyword |
No |
is the identifier number of the element |
Integer |
No |
is the property identifier number of the element |
Integer |
No |
are the identifier numbers of the node connectivity of the shell |
Integer |
No |
String |
No |
is the thickness of the node_i |
Real |
Length |
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
9 |
10 |
CTRIA3 |
EID |
PID |
Node_1 |
Node_2 |
Node_3 |
cflag |
cflag |
TH_1 |
TH_2 |
TH_3 |
Where: |
Type |
Unit |
is the keyword for the 3 nodes shell element |
Keyword |
No |
Integer |
No |
Integer |
No |
Integer |
No |
String |
No |
Real |
Length |
BEGIN BULK GRID* 1 -8.6314740e+02 -5.3617853e+02 1000001 *1000001 2.0918124e+02 GRID* 2 -8.6434418e+02 -5.3400195e+02 1000002 *1000002 2.0917842e+02 GRID* 3 -8.6554608e+02 -5.3181616e+02 1000003 *1000003 2.0917554e+02 GRID* 4 -8.6674969e+02 -5.2962726e+02 1000004 *1000004 2.0917262e+02 CQUAD4 1 4 2397 181 149 23980.0000000.000000+E100001 +E100001 1.5586081.5552421.5613061.560449 CQUAD4 2 4 2398 149 150 23990.0000000.000000+E100002 +E100002 1.5604491.5613061.5553691.560354 CQUAD4 3 4 2400 151 152 24010.0000000.000000+E100003 +E100003 1.5492411.5470191.5443201.554353 CTRIA3 83 4 2480 2479 63 +E100083 +E100083 1.3716001.3562011.357757 CQUAD4 84 4 2401 152 153 24020.0000000.000000+E100004 +E100004 1.5543531.5443201.5341601.559306 |
