1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
9 |
AMAP |
Where: |
Type |
Unit |
is a keyword |
Keyword |
No |
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
9 |
Nb_ci |
Nb_Nodes |
Where: |
Type |
Unit |
is the number of control information which is presently equal to 6 |
Integer |
No |
is the number of nodes in the model |
Integer |
No |
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
9 |
NODE / |
Node_id |
x_coord |
y_coord |
z_coord |
Where: |
Type |
Unit |
is a keyword |
Keyword |
No |
is the identifier of the node |
Integer |
No |
is the i coordinate value of the node in the global frame |
Real |
Length |
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
9 |
SHELL / |
Elem_id |
Node_1 |
Node_2 |
Node_3 |
Node_4 |
NPT |
NPS |
Where: |
Type |
Unit |
is a keyword |
Keyword |
No |
Integer |
No |
is the node identifier number of the shell connectivity |
Integer |
No |
is the number of integration point through the thickness |
Integer |
No |
is the number of Gauss points on the shell surface (not currently used) |
Integer |
No |
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
9 |
Var_key |
Nb_values |
NPT_dpd |
NPS_dpd |
Where: |
Type |
Unit |
is the variable type keyword. THIC, PLAS and STRS keywords are taken into account (other keywords are ignored). |
Integer |
No |
is the number of values to be read for this variable |
Integer |
No |
is a flag for the dependency on the number of integration points through the thickness and which can be:
Integer |
No |
is a flag for the dependency on the number of Gauss points (not used today) and which can be:
Integer |
No |
1* |
2* |
3* |
4* |
5* |
6* |
Var_1(1,1,1) |
Var_1(2,1,1) |
Var_1(Nb_values,1,1) |
Var_1(1,2,1) |
Var_1(Nb_values,NPT,1) |
Var_2(1,1,1) |
Var_Nv(Nb_values,NPT,1) |
Var_Ns(1,1,1) |
*field of 13 digits.
Where: |
Type |
Unit |
is a specific variable type (thickness, plastic strain …) |
Real |
Length, Force/length2 or no unit |
is the number of values per variable |
Integer |
No |
Integer |
No |
is the number of variables |
Integer |
No |
is the number of 3 nodes and 4 nodes shell elements |
Integer |
No |
AMAP 6 10528 NODE / 9276 .71720192E+02 -.44168634E+03 -.11976915E+02 NODE / 9277 .73868263E+02 -.44167099E+03 -.98283386E+01 NODE / 9278 .75555687E+02 -.44165979E+03 -.73018613E+01 NODE / 9279 .76718987E+02 -.44165094E+03 -.44946604E+01 SHELL / 9025 9025 9057 9058 9026 3 1 SHELL / 9026 9026 9058 9059 9027 3 1 SHELL / 9027 9027 9059 9060 9028 3 1 SHELL / 9028 9028 9060 9061 9029 3 1 THIC 6 1 0 1 1 0 0 PLAS 6 1 1 1 0 0 0 STRS 6 5 1 1 -1 1 -2 .100002E+01 .000000E+00 .000000E+00 .000000E+00 -.191125E-03 -.685494E-05 .543749E-04 .000000E+00 .000000E+00 -.220166E-03 -.492977E-04 .334407E-04 .000000E+00 .000000E+00 -.249215E-03 -.914052E-04 .124898E-04 .000000E+00 .000000E+00 .100004E+01 .000000E+00 .000000E+00 .000000E+00 .194877E-03 .105157E-03 -.277142E-04 .000000E+00 .000000E+00 .208800E-03 .895069E-04 -.716815E-04 .000000E+00 .000000E+00 .222600E-03 .736836E-04 -.115605E-03 .000000E+00 .000000E+00 .100003E+01 .000000E+00 .000000E+00 .000000E+00 -.163653E-03 -.141608E-03 .168436E-03 .000000E+00 .000000E+00 -.175705E-03 -.141802E-03 .103958E-03 .000000E+00 .000000E+00 -.187603E-03 -.141966E-03 .394956E-04 .000000E+00 .000000E+00 .100006E+01 .000000E+00 .000000E+00 .000000E+00 .137944E-03 .227799E-03 -.359828E-04 .000000E+00 .000000E+00 .125826E-03 .198729E-03 -.117759E-03 .000000E+00 .000000E+00 .113734E-03 .169621E-03 -.199548E-03 .000000E+00 .000000E+00 |
