Results Mapper is able to read the user format as defined following:
*NODE
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
9 |
10 |
id |
X_coord |
Y_coord |
Z_coord |
Where: |
Type |
Unit |
is the keyword |
Keyword |
No |
is the identifier number of the node |
Integer |
No |
are the coordinate values of the node in the global frame |
Real |
No |
*ELEMENT_SHELL_THICKNESS
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
9 |
10 |
EID |
PID |
Node_1 |
Node_2 |
Node_3 |
Node_4 |
TH_1 |
TH_2 |
TH_3 |
TH_4 |
Where: |
Type |
Unit |
is a keyword |
Keyword |
No |
is the identifier number of the element |
Integer |
No |
is the part identifier number of the element |
Integer |
No |
are the identifier numbers of the node connectivity of the shell |
Integer |
No |
is the thickness of the node_i |
Real |
Length |
*INITIAL_STRESS_SHELL
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
EID |
NPLANE |
NTHICK |
T |
SIGXX |
SIGYY |
SIGZZ |
SIGXY |
SIGYZ |
SIGZX |
EPS |
Where: |
Type |
Unit |
is a keyword |
Keyword |
No |
Integer |
No |
Integer |
No |
Integer |
No |
For each NTHICK and NPLANE:
Where: |
Type |
Unit |
is the parametric coordinate of through thickness integration point |
Real |
No |
are the tensor stress values |
Real |
Pressure |
is the effective plastic strain |
Real |
No |
*NODE $ NODE X Y Z TC RC 19891 -0.10000000E-04 0.60475000E+03 -0.34046400E+03 1 0 19892 -0.40078700E+02 0.60280680E+03 -0.34044900E+03 0 0 19893 -0.80098000E+02 0.59983900E+03 -0.34043500E+03 0 0 19894 -0.11991700E+03 0.59482330E+03 -0.34042300E+03 0 0 19895 -0.15930000E+03 0.58709760E+03 -0.34041400E+03 0 0 *ELEMENT_SHELL_THICKNESS $ EID PID N1 N2 N3 N4 $ T1 T2 T3 T4 19519 65871 20698 20219 19918 20221 0.100753E+01 0.100425E+01 0.961544E+00 0.974212E+00 19520 65871 20220 19917 20219 20698 0.104208E+01 0.104628E+01 0.100425E+01 0.100753E+01 19521 65871 19948 20220 20698 20224 0.103773E+01 0.104208E+01 0.100753E+01 0.101316E+01 *INITIAL_STRESS_SHELL $ EID NPLANE NTHICK $ T SIGXX SIGYY SIGZZ SIGXY SIGYZ SIGZX EPS 19519 4 5 -0.906E+00 0.195E+03-0.214E+03 0.429E-01-0.263E+02 0.108E+01 0.323E+01 0.179E+00 -0.906E+00 0.294E+03-0.969E+02 0.127E+00-0.603E+02-0.542E+00 0.621E+01 0.227E+00 -0.906E+00 0.346E+03-0.297E+01 0.955E-01-0.346E+02-0.509E+00 0.577E+01 0.167E+00 -0.906E+00 0.396E+03 0.800E+02 0.188E+00-0.629E+02-0.206E+01 0.847E+01 0.239E+00 -0.538E+00 0.213E+03-0.197E+03 0.375E-01-0.256E+02 0.103E+01 0.318E+01 0.182E+00 -0.538E+00 0.307E+03-0.839E+02 0.112E+00-0.594E+02-0.507E+00 0.598E+01 0.231E+00 -0.538E+00 0.359E+03 0.109E+02 0.821E-01-0.334E+02-0.584E+00 0.540E+01 0.173E+00 -0.538E+00 0.405E+03 0.891E+02 0.166E+00-0.616E+02-0.203E+01 0.799E+01 0.246E+00 0.000E+00 0.239E+03-0.174E+03 0.287E-01-0.247E+02 0.951E+00 0.300E+01 0.188E+00 0.000E+00 0.326E+03-0.656E+02 0.911E-01-0.579E+02-0.463E+00 0.556E+01 0.239E+00 0.000E+00 0.377E+03 0.298E+02 0.637E-01-0.317E+02-0.691E+00 0.478E+01 0.182E+00 0.000E+00 0.418E+03 0.102E+03 0.135E+00-0.597E+02-0.200E+01 0.723E+01 0.255E+00 0.538E+00 0.263E+03-0.151E+03 0.196E-01-0.238E+02 0.868E+00 0.270E+01 0.194E+00 0.538E+00 0.344E+03-0.482E+02 0.711E-01-0.565E+02-0.426E+00 0.504E+01 0.247E+00 0.538E+00 0.392E+03 0.474E+02 0.476E-01-0.300E+02-0.794E+00 0.408E+01 0.191E+00 0.538E+00 0.431E+03 0.114E+03 0.107E+00-0.580E+02-0.196E+01 0.642E+01 0.265E+00 0.906E+00 0.279E+03-0.136E+03 0.137E-01-0.231E+02 0.809E+00 0.242E+01 0.198E+00 0.906E+00 0.355E+03-0.367E+02 0.584E-01-0.555E+02-0.404E+00 0.464E+01 0.252E+00 0.906E+00 0.402E+03 0.585E+02 0.381E-01-0.290E+02-0.862E+00 0.356E+01 0.198E+00 0.906E+00 0.438E+03 0.122E+03 0.901E-01-0.568E+02-0.195E+01 0.583E+01 0.272E+00 19520 4 5 -0.906E+00 0.185E+03-0.232E+03 0.260E-01-0.991E+01 0.154E+00 0.220E+01 0.180E+00 -0.906E+00 0.173E+03-0.243E+03 0.433E-01-0.307E+01 0.209E+00 0.274E+01 0.178E+00 -0.906E+00 0.161E+03-0.257E+03 0.182E-01-0.865E+01 0.108E+01 0.195E+01 0.186E+00 -0.906E+00 0.150E+03-0.267E+03 0.327E-01-0.200E+01 0.115E+01 0.238E+01 0.184E+00 -0.538E+00 0.184E+03-0.232E+03 0.260E-01-0.988E+01 0.154E+00 0.220E+01 0.180E+00 -0.538E+00 0.173E+03-0.243E+03 0.432E-01-0.303E+01 0.210E+00 0.274E+01 0.178E+00 -0.538E+00 0.161E+03-0.257E+03 0.181E-01-0.862E+01 0.108E+01 0.195E+01 0.186E+00 -0.538E+00 0.150E+03-0.267E+03 0.326E-01-0.196E+01 0.115E+01 0.238E+01 0.184E+00 ... |
