| 1. | From the Menu Bar, select Connections > Bolt > Criteria. |
The Bolt Settings window opens.
| 2. | Select the appropriate criteria to check by clicking the appropriate check box. |
| 3. | Enter the desired values for each parameter (it is recommended to use the default values). |
| 4. | Click Save to validate. |
| 5. | To reset to the default values, click Reset. |
| 6. | From the Menu Bar, select Connections > Bolt > Check. |
HyperCrash opens the window Bolt, Modify. The bolts which do not conform to a criteria are displayed in orange in the list.
To learn why the bolt is incorrect and to modify it:
| 1. | Select a bolt in the listing window. |
| 2. | Click to display the bolt and to open the modification menu. |
| 3. | Check the message in the message window to learn why the bolt is incorrect (message is in green). |
| 5. | Click Save to save the bolt modification; or |
Click Cancel to cancel the bolt modification.
| 6. | Click Close to close the menu. |
See also
Bolt
Export File
