This function exports positions in a HyperCrash file format.
1. | From the Menu Bar, select Connections > [connection type] > Export File > All [connection type] .... |
A sub-window for setting the file name appears.
2. | Choose a directory and enter a file name. |
3. | Click OK to save in a file; or |
Click Cancel to close the sub-window.
This function exports all the positions from the tree selection.
1. | From the Menu Bar, select Connections > [connection type] > Export File > [connection type] from Tree Selection. |
3. | Click OK to save a file; or |
This function exports all the positions and set of properties in a file format.
1. | From the Menu Bar, select Connections > [connection type] > Export File > All [connection type] with Property Id. |
This function exports the positions in CSV format.
1. | From the Menu Bar, select Connections > [connection type] > Export File > All [connection type] in CSV Format. |
