Use the Unit System option from the RADIOSS Tools menu to create, delete, edit, clone or cross reference a /UNIT card.
In the Unit System panel, right-click to access the context menu, and make a selection from the available choices.
1. | When you select Create New from the context menu, the /UNIT card panel appears. |
Button |
Behavior |
select/unselect all |
review |
create a new object |
pick parts to see in the list and then press Enter, right-click the mouse button or select Yes or Cancel in the Dialog menu bar. |
select parts in tree to see object in the list. |
cross reference |
show/hide checks |
delete selected item(s). |
2. | Click to edit fields and right-click in applicable fields for more options. |
3. | Click Save or Cancel when you are finished creating the card. |
