To import an accelerometer position from test data |
| 1. | From the Menu Bar, select Data History > Accelerometer > Import Test Data.... |
or
If the Data History panel is open, select Accelerometer > Import Test Data... from the pull-down menu.
An Import Test Data dialog appears.
| 2. | Select a file name. |
| 3. | Enter a name in the Name of the Time History field. |
| 4. | Set the Gap value for the automatic research of the closest node. |
| 5. | Set the Cut Frequency (cutoff frequency) value. |
The default parameters are defined in the environment files.
| 6. | Click OK to open the selected file; or |
Click Cancel to close the window and cancel the function.
The accelerometers will be automatically created. The creation can be checked in the modify page.
The formats of the text file are defined in the main documentation.
