| 1. | From the Menu Bar, select Data History > Accelerometer > Modify. |
or
If the Data History panel is open, select Accelerometer > Modify from the pull-down menu.
| 2. | In the Accelerometer to modify list, click the accelerometer. |
| 3. | Click to display the accelerometer in the graphic window. |
It is possible to:
| • | Modify the accelerometer's name by setting a new name in the Accel. name field and validating with Ok. |
| 4. | Click Save to save the accelerometer modifications; or |
Click Cancel to cancel the accelerometer modifications.
| 5. | Click Close to close the menu. |
