| 1. | From the Menu Bar, select Data History > Accelerometer > Modify. |
or
If the Data History panel is open, select Accelerometer > Modify from the pull-down menu.
| • | Click to select all the accelerometers. |
or
| • | Click the accelerometer line in the listing window to select it. Several accelerometers from this list can be selected using the SHIFT, CTRL, or SHIFT+CTRL keys. |
| 3. | Click to delete all the selected accelerometers. |
| 4. | Answer the question in the Dialog menu bar with Yes or Cancel. |
| 5. | Click Close to close the menu. |
