1. | From the Menu Bar, select Data History > Part > Create. |
or
If the Data History panel is open, select Part > Create from the pull-down menu.
2. | Enter a name in the Part for time history field and validate with Ok. |
3. | Click and pick a part in the graphic window. When finished, answer the question in the Dialog menu bar with Yes or Cancel. |
or
Click to include the part selected in the tree.
or
Set a part ID in the Part Id field and click Ok.
4. | Click Save to save the time history parts; or |
Click Cancel to cancel the time history parts creation.
5. | Click Close to close the menu. |
