1. | From the Menu Bar, select Data History > Part > Modify. |
or
If the Data History panel is open, select Part > Modify from the pull-down menu.
2. | In the TH to modify list, click on the group to modify. |
3. | Click to display the time history part(s) in the graphic window. |
It is possible to:
• | Modify the TH part group name by setting a new name in the TH name field. |
4. | Click Save to save the time history part modifications; or |
Click Cancel to cancel the time history part modifications.
5. | Click Close to close the menu. |
