| 1. | From the Menu Bar, select Data History > Part > Modify. |
or
If the Data History panel is open, select Part > Modify from the pull-down menu.
It is possible to directly delete a time history part group or, within a group, to delete a time history part.
Delete a time history part group
| 1. | Click the time history part group to be deleted. |
| 2. | Click . |
| 3. | Answer the question in the Dialog menu bar with Yes or Cancel. |
Delete a time history part from a group
| 1. | Click the time history part group in which a time history part is to be deleted. |
| 2. | Click to display the time history part(s) in the graphic window. |
| 3. | From the time history part list, select the time history part to be deleted. |
| 4. | Click . |
| 5. | Answer the question in the Dialog menu bar with Yes or Cancel. |
| 6. | Click Close to close the menu. |
