To set this option add the file, $MCRASHDIR/includes/include_list with the parameter defined as follows.
To unset this option, remove (or rename) the file, $MCRASHDIR/includes/include_list or set the character, # can be set on the top of the line on the parameters you do not want to see.
The file, $MCRASHDIR/includes/include_list contains a list of RADIOSS data type that can be searched in a database include file at the writing of the D00. After each type of data, there is the path of the data base file to search.
| Note: | Currently, only material is available. |
/ENTITY
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
9 |
10 |
<full path> file_name |
Where: |
Type |
Unit |
Is a keyword which can be:
Keyword |
No |
is the file name (with its full path) of the stored include file. |
String |
No |
/MATERIAL /usr/people/project1/mat_file |
If you select to ”include a data base material file", the following line is written in the RADIOSS input deck (D00 file):
#include/usr/people/project1/mat_file
and no material cards will be written in the RADIOSS input deck (D00 file).
