The file default_mat_prop.txt is located inside the directory $MCRASHDIR/defaults. This file contains the default material and/or properties which will be used during the file input.
/INPUT/input_file_type/input_type
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
9 |
10 |
<full path> file_name |
Where: |
Type |
Unit |
is a keyword |
Keyword |
No |
is the type of file which can be:
Keyword |
No |
is the type of input which can be:
Keyword |
No |
is the file name which contains all the defaults properties and material of the file input type |
String |
No |
This card defined the beginning and the end of the default definition of the material and property for the defined input file type.
/input_file_type/state
Where: |
Type |
Unit |
is a keyword |
Keyword |
No |
is a keyword:
Keyword |
No |
Between the card BEGIN and END, the property and the material linked to each type of element can be defined as follows:
/element_type/input_type/input_type_id
Where: |
Type |
Unit |
Keyword |
No |
Keyword |
No |
is the identifier of the property or material card. |
Integer |
No |
File: default_mat_prop.txt
/INPUT/NASTRAN/PROP $MCRASHDIR/defaults/nastran.def /INPUT/NASTRAN/MAT $MCRASHDIR/defaults/nastran.def /NASTRAN/BEGIN /PART_SHELL/PROP/1 /PART_SHELL/MAT/3 /PART_SOLID/PROP/2 /PART_SOLID/MAT/3 /NASTRAN/END
File: propD00
#RADIOSS STARTER 41 #--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---| /PROP/TYPE1/1/DEFAULT SHELL #-Ishel| Ismstr| 0 0 #- hm | hf | hr | dm | 0 0 0 0 #- N |Istrain| Thick | Ashear | | Ithick| Iplas| 5 0 0.7 0 2 0 #--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---| /PROP/TYPE14/25/DEFAULT SOLID #-Isoli| Ismstr| 1 2 #- q_a | q_b | h | 1.1 0.05 0.1 #--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---| /PROP/TYPE3/234/DEFAULT_BEAM #- | Ismstr| 0 #- dm | df | 0 0 #- Area | Iyy | Izz | Ixx | 314 796 796 1592 #- Rot | Ishear| 000 000 0 #--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---| /END
File: matD00 #RADIOSS STARTER 41 #--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---| /MAT/LAW2/1/DEFAULT_STEEL_MATERIAL # Init. dens. Ref. dens. #- Rho_i | Rho_0 | 1.2e-09 0 #- E | Nu | 2800 0.3 #- a/C0 | b/C5 | n | Eps_max | sigma_max | 192 200 0.32 0 0 #- c/C1 | Eps_0 | Icc | 0 0 0 #- m/C3 | T_melt/C4 | rhoCp | T_i | 0 0 0 0 #--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---| /MAT/LAW1/234/DEFAULT_ELASTIC_MATERIAL # Init. dens. Ref. dens. #- Rho_i | Rho_0 | 7.89e-09 0 #- E | Nu | 210000 0.3 #--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---| /END |
Main Module Environment File Description
