The file, $MCRASHDIR/menu/mcrash.menu defines the menus that will appear in the HyperCrash session. Currently, not all menus available in HyperCrash are defined in this menu file. They will be implemented during the HyperCrash development.
/MCRASH/key_menu/menu_title
Where: |
Type |
Unit |
is a keyword |
Keyword |
No |
is the keyword of the menu which can be:
Keyword |
No |
is the name of the menu displayed in HyperCrash |
Keyword |
No |
/key_menu/key_function/funct_title
Where: |
Type |
Unit |
is the keyword of the menu |
Keyword |
No |
is the keyword of the function in the menu |
Keyword |
No |
is the name of the function displayed in HyperCrash |
Keyword |
No |
key_menu |
Associated key_function |
DISCONNECTION |
NODES SPRINGS |
AUTOMATIC |
SPOTWELD GLUE HEMMING WELDLINE |
SPOTMENU |
CHANGE_PROP |
BOLTMENU |
CREATE MODIFY CHECK CRITERIA CLOSE |
GLUEMENU |
CREATE MODIFY CHECK CRITERIA ALL_EXT SEL_EXT CLOSE |
WELDMENU |
HEMMMENU |
Several function cards can be defined for each menu card.
/END
Where: |
Type |
Unit |
Keyword to finish the input. |
Keyword |
No |
# # MCRASH : menu # /MCRASH/FILE/File /FILE/MESH_FILE/Mesh... /FILE/READ_NAS_FOR_CRASH/Nastran for Crash... /FILE/READ_NAS_FOR_NAS/Nastran for Nastran... /FILE/NEWREADPAM/PAM 2G... /FILE/READ_UNV/.UNV File... /FILE/ANSYS/.CDB File... /FILE/READ_DYNA/LS-DYNA... /FILE/WRITE_NASTRAN/Nastran... /FILE/WRITE_UNV/.UNV File /FILE/WRITEPAM2G/PAM2G... /FILE/WRITE_DYNA/LS-DYNA... # /MCRASH/DISCONNECTION/Disconnection /DISCONNECTION/NODES/Nodes Disconnection /DISCONNECTION/SPRINGS/Rigid Bodies,Rivets and Springs # /MCRASH/CONAUTOMENU/Automatic /CONAUTOMENU/SPOTWELD/Spotweld /CONAUTOMENU/GLUE/Glue /CONAUTOMENU/HEMMING/Hemming /CONAUTOMENU/WELDLINE/Weldline # /MCRASH/SPOTMENU/Spotweld /SPOTMENU/CREATE/Create /SPOTMENU/MODIFY/Modify /SPOTMENU/CHECK/Check /SPOTMENU/CRITERIA/Criteria... /SPOTMENU/CUSTOMIZE/Customize... /SPOTMENU/CHANGE_PROP/Modify Prop. /SPOTMENU/ALL_EXT/Extract from Model /SPOTMENU/SEL_EXT/Extract from Tree Selection /SPOTMENU/EXP_SEL_CON_ELEM/Export Selected Connections /SPOTMENU/CLOSE/Close # /MCRASH/BOLTMENU/Bolt /BOLTMENU/CREATE/Create /BOLTMENU/MODIFY/Modify /BOLTMENU/CHECK/Check /BOLTMENU/FILE/Import from File... /BOLTMENU/CRITERIA/Criteria... /BOLTMENU/CUSTOMIZE/Customize... /BOLTMENU/EXP_SEL_CON_ELEM/Export Selected Connections /BOLTMENU/CLOSE/Close # /MCRASH/GLUEMENU/Glue /GLUEMENU/CREATE/Create /GLUEMENU/MODIFY/Modify /GLUEMENU/CHECK/Check /GLUEMENU/FILE/Import from File... /GLUEMENU/CUSTOMIZE/Customize... /GLUEMENU/CHANGE_PROP/Modify Prop. /GLUEMENU/CRITERIA/Criteria... /GLUEMENU/ALL_EXT/Extract from Model /GLUEMENU/SEL_EXT/Extract from Tree Selection /GLUEMENU/EXP_SEL_CON_ELEM/Export Selected Connections /GLUEMENU/CLOSE/Close # /MCRASH/WELDMENU/Welding Line /WELDMENU/CREATE/Create /WELDMENU/MODIFY/Modify /WELDMENU/CHECK/Check /WELDMENU/FILE/Import from File... /WELDMENU/CRITERIA/Criteria... /WELDMENU/CUSTOMIZE/Customize... /WELDMENU/CHANGE_PROP/Modify Prop. /WELDMENU/ALL_EXT/Extract from Model /WELDMENU/SEL_EXT/Extract from Tree Selection /WELDMENU/EXP_SEL_CON_ELEM/Export Selected Connections /WELDMENU/CLOSE/Close # /MCRASH/HEMMMENU/Hemming /HEMMMENU/CREATE/Create /HEMMMENU/MODIFY/Modify /HEMMMENU/CHECK/Check /HEMMMENU/FILE/Import from File... /HEMMMENU/CRITERIA/Criteria... /HEMMMENU/CUSTOMIZE/Customize... /HEMMMENU/CHANGE_PROP/Modify prop. /HEMMMENU/ALL_EXT/Extract from Model /HEMMMENU/SEL_EXT/Extract from Tree Selection /HEMMMENU/EXP_SEL_CON_ELEM/Export Selected Connections /HEMMMENU/CLOSE/Close # /MCRASH/EXPORTCONMENU/Export Connection File... /EXPORTCONMENU/MWFSPOT/All Spotwelds with Property Id... /EXPORTCONMENU/CSVSPOT/All Spotwelds in CSV Format... /EXPORTCONMENU/MFCSPOT/All Spotwelds as MFC XML Format... /EXPORTCONMENU/MFCSPOP/Spotwelds from Tree Selection as MCF XML Format... /EXPORTCONMENU/MECASPOP/Spotwelds from Tree Selection... /EXPORTCONMENU/MECAWELD/All Welding Lines... /EXPORTCONMENU/MECAWELP/Welding Lines from Tree Selection... /EXPORTCONMENU/MWFWELD/All Welding Lines with Property Id... /EXPORTCONMENU/MFCWELD/All Welding Lines as MFC XML Format... /EXPORTCONMENU/MFCWELP/Welding Lines from Tree Selection as MCF XML Format... /EXPORTCONMENU/MECAHEM/All Hemmings... /EXPORTCONMENU/MECAHEMP/Hemmings from Tree Selection... /EXPORTCONMENU/MWFHEM/All Hemmings with Property Id... /EXPORTCONMENU/MFCHEM/All Hemmings as MFC XML Format... /EXPORTCONMENU/MFCHEMP/Hemmings from Tree Selection as MCF XML Format... /EXPORTCONMENU/MECAGLUE/All Glues... /EXPORTCONMENU/MECAGLUP/Glues from Tree Selection... /EXPORTCONMENU/MWFGLU/All Glues with Property Id... /EXPORTCONMENU/MFCGLU/All Glues as MFC XML Format... /EXPORTCONMENU/MFCGLUP/Glues from Tree Selection as MCF XML Format... /EXPORTCONMENU/MECABOLT/All Bolts... /EXPORTCONMENU/MECABOLP/Bolts from Tree Selection... /EXPORTCONMENU/MFCBOLT/All Bolts as MFC XML Format... /EXPORTCONMENU/MFCBOLP/Bolts from Tree Selection as MCF XML Format... # /MCRASH/MSAFETYMENU/Safety /MSAFETYMENU/SEAT_DEFORMER/Seat Deformer /MSAFETYMENU/DUMMY_POS/Dummy Positioner /MSAFETYMENU/BELT_GENERATOR/Belt Generator /MSAFETYMENU/AIRBAG/Airbag Folder /MSAFETYMENU/HCOMFORT/HComfort # # Menu # /MCRASH/MODULECHOICE/File /MODULECHOICE/MSAFETY/Safety #/MODULECHOICE/MXPLORE/Study /MODULECHOICE/MXCHANGE/Results Mapper /MODULECHOICE/SUBMODEL/Submodeling /MODULECHOICE/TIMESTEP/Element Timestep # /MCRASH/MESHEDIT/Mesh Editing /MESHEDIT/RLINK/Rigid Link /MESHEDIT/CYL_JOINT/Cylindrical Joint /MESHEDIT/DAMP/Rayleigh Damping # /MCRASH/LOADCASEMENU/LoadCase /LOADCASEMENU/IMPACC/Imposed Acceleration /LOADCASEMENU/PLOAD/Pressure Load # # # Toolbar # list all the modules to be added /MCRASH/TOOLBAR/MODULES /TOOLBAR/TOOLBAR_LOADCASE/NULL /TOOLBAR/TOOLBAR_CONNECTIONS/NULL /TOOLBAR/TOOLBAR_TOOLS/NULL # # loadcase toolbar # /MCRASH/TOOLBAR_LOADCASE/Loadcases /TOOLBAR_LOADCASE/BCS/Boundary Conditions /TOOLBAR_LOADCASE/CLOAD/Concentrated Loads /TOOLBAR_LOADCASE/GRAV/Gravity Loads /TOOLBAR_LOADCASE/IMPVEL/Imposed Velocities /TOOLBAR_LOADCASE/IMPACC/Imposed Accelerations /TOOLBAR_LOADCASE/IBVEL/Imposed Body Velocities /TOOLBAR_LOADCASE/IMPDISP/Imposed Displacements /TOOLBAR_LOADCASE/INIVEL/Initial Velocities /TOOLBAR_LOADCASE/PLOAD/Pressure Loads # # # connection Toolbar # # /MCRASH/TOOLBAR_CONNECTIONS/Connections /TOOLBAR_CONNECTIONS/MCDS_RBE3/RBE3 /TOOLBAR_CONNECTIONS/RBODY/Rigid Bodies /TOOLBAR_CONNECTIONS/CYL_JOINT/Cylindrical Joints /TOOLBAR_CONNECTIONS/RLINK/Rigid Link /TOOLBAR_CONNECTIONS/E_BOLT/Bolts /TOOLBAR_CONNECTIONS/E_GLUE/Glues /TOOLBAR_CONNECTIONS/E_HEMMING/Hemmings /TOOLBAR_CONNECTIONS/E_SPOTWELD/Spotwelds /TOOLBAR_CONNECTIONS/E_WELDING_LINE/Welding Lines # # # Tools Toolbar # /MCRASH/TOOLBAR_TOOLS/Tools /TOOLBAR_TOOLS/RWALL/Rigid Walls /TOOLBAR_TOOLS/INTER/Contact Interfaces /TOOLBAR_TOOLS/MONVOL/Monitored Volumes /TOOLBAR_TOOLS/SECT/Sections /TOOLBAR_TOOLS/ADMAS/Added Masses /TOOLBAR_TOOLS/ACCEL/Accelerometers # # /END |
