In this directory are the necessary files to define specific user options.
To set and unset the option, the corresponding file has to be removed or the file needs to be renamed.
This option can:
• | Renumber the part with the same ID as the property |
• | Renumber the nodes of each part from part_ID*10000 to part_ID*10000+9999 |
• | Renumber the elements of each part from part_ID*10000 to part_ID*10000+9999 |
This option is activated with the file, $MCRASHDIR/option/renum_file which contains:
/RENUMBERING/WHERE/TYPE/FLAG/PART/OPTION
Where: |
Type |
Unit |
is a keyword |
Keyword |
No |
is a keyword which defined where the renumbering will appears:
Keyword |
No |
is a keyword which defined the type renumbering
Keyword |
No |
is a keyword which defines:
Keyword |
No |
is a keyword |
Keyword |
No |
is a keyword which defined:
Keyword |
No |
This card is necessary only if the option RENUM_ALL is used.
/TITLE/title_name
Where: |
Type |
Unit |
is a keyword |
Keyword |
No |
is the name of the option which will be displayed in HyperCrash. |
String |
No |
/END
Where: |
Type |
Unit |
Keyword to finish the input. |
Keyword |
No |
This option can release the license when the user does not answer a question during a defined time.
This option is activated with the file, $MCRASHDIR/option/license_opt which contains:
TIMEOUT feature time
Where: |
Type |
Unit |
is a keyword |
Keyword |
No |
is name of the feature to release after the time value
Keyword |
No |
is the time value in second |
Real |
Second |
After the defined time value, the HyperCrash license is released and can be used by somebody else.
When the time value is exceeded and if the user wants to continue to use the HyperCrash, HyperCrash will request a new license to FLEXLM. If there are no more licenses available, only the HyperCrash function "output” will be available to save the model.
