Reads an ASCII file containing floating point numbers (in a completely free format).
fplist = READ_FPL(
filename
fplist
The resulting floating point list object.
filename
The name of the input file (string of characters).
The format of the file is free. The file is read until the end or until a wrong floating point expression is encountered. The numbers may be separated by empty lines.
