| 1. | From the Menu Bar, select Model > Property. |
| 3. | Select the property from the tree. |
| 4. | Click the Isolate Tree Selection icon. |
| 5. | Go back to the Property panel. |
| 6. | Click to select parts. |
| 7. | Click to view the selected parts. |
The property parameters appear in the panel.
| 10. | Click Close to close the Property panel. |
Property modification
If only one property is selected, HyperCrash will automatically open this property in order to modify it.
| 1. | Click and pick parts in the graphic window to select or deselect them. |
| 2. | Click to add or remove the parts from the tree selection. |
| 3. | Enter the different values in the fields for the property. |
| • | Set the value or the property name. |
| • | Click the toggle button to switch options ON or OFF. |
| • | Click the button for the function to set or modify a function. |
| • | Set the number for the function needed and click Ok. |
| 4. | Click to save this property (as a RADIOSS input deck file): |
| • | In the new sub-window, select the directory to save the property to (left area part). |
| • | Enter the name of the property to save. |
| • | Select OK to save the property or Cancel to cancel the save. |
| 5. | Click Save to save the property creation; or |
Click Cancel to cancel the property creation.
| 6. | Click Close to close the menu. |
