Function Setting
Click the functions icon.
Create a new function
| 1. | Set the function name in the Function name field. |
| 2. | Set the different optional fields. |
| 3. | Create several points on the curve: |
| • | Set an abscissa value in the field, t. |
| • | Set the ordinate value in the field, f(t). |
| • | Validate both input values by clicking Validate. |
| 4. | Repeat the operations until all the points of the curves are created. |
Modify a function
| 1. | Modify the function name in the Function name field. |
| 2. | Modify the different optional fields. |
| 4. | Repeat the operations until all the new points are added. |
Modify a point
| 1. | Select the line in the curve point list. |
| 2. | Modify the abscissa value in the field, t. |
| 3. | Modify the the ordinate value in the field, f(t). |
| 4. | Validate the point by clicking Validate. |
Remove point(s) on the curve
| 1. | Select line(s) in the curve point list. |
or
Click
to select all the points.
| 2. | Click to delete the selected point(s). |
Import a function from an external file
| 2. | In the new sub-window, select the directory for the function to read (left area part). |
| 3. | Enter the name of the function to read. |
| 4. | Select OK to read the function or Cancel to cancel the reading. |
| 5. | Click OK to save the new function or the modifications; or |
Click Cancel to cancel the function creation or the modifications.
