| 1. | From the Menu Bar, select Process > Model Manager > Maintenance. |
| 2. | Select the Database > Keyword tabs. |
| 3. | In the Keyword Type / New area, enter the keyword type. (Example: enter "Model type" and click OK.) |
| 4. | In the Keyword / New area, enter the attributes of the keyword type and click OK. (Example: enter "FEM" and click OK.) |
All the new keywords are written in the Validation window.
| 5. | Click Validate to save the keywords. Answer the question at the bottom-right of the screen with Yes or No. |
or
Click Clear All to remove the keywords. Answer the question at the bottom-right of the screen with Yes or No.
Example of <install directory>/environment/.../modmng/keyword.tbl file:
Keyword type: component.
with the keywords: MOTOR, DOOR, TIRE, ENGINE, SEAT, RADIATOR, FUEL TANK, ODB.
Keyword type: Model Type.
with the keywords: FEM, BEAM, RBODY, MASS.
Keyword type: Crash type.
with the keywords: FRONT, REAR, SIDE, ALL.
