Select Yes, No or Cancel to answer the question displayed on the Dialog menu bar which appears at the bottom of the screen.
The following shortcuts can also be used:
| • | The ENTER and Y keys have the same function as Yes. |
| • | The N key has the same function as No. |
| • | The ESC key has the same function as Cancel. |
| • | Right-click the mouse to accept part(s) selected. |
