| 1. | From the Menu Bar, select Data History > Relative Displacement > Modify. |
or
If the Data History panel is open, select Relative Displacement > Modify from the pull-down menu.
It is possible to directly delete a relative displacement group or; in a group, to delete a relative displacement.
Delete a relative displacement group
| 1. | Click the relative displacement group to be deleted. |
| 2. | Click . |
| 3. | Answer the question in the Dialog menu bar with Yes or Cancel. |
Delete a relative displacement in a group
| 1. | Click the relative displacement group from which a relative displacement is to be deleted. |
| 2. | Click to display the relative displacement(s) in the graphic window. |
| 3. | In the Relative displacement list, select the relative displacement to be deleted. |
| 4. | Click . |
| 5. | Answer the question in the Dialog menu bar with Yes or Cancel. |
| 6. | Click Close to close the menu. |
