Creates a new model obtained by folding of the model given as argument.
fmodel = FOLD( model, plan, line, el_size, gap_mini, tan_alpha ) ;
fmodel
The name of the folded model.
model
The name of the model object to be folded.
plan
The mean plane of the model to be folded.
line
The folding line.
el_size
The minimum element size.
gap_mini
The minimum gap between folded surfaces.
tan_alpha
The maximum slope of inclined surfaces created around the fold line.
fmodel = FOLD( model, line, el_size, gap_mini, tan_alpha ) ;
fmodel
model
line
The folding line.
el_size
gap_mini
tan_alpha
The operation of folding is quite complex. See the Airbag Folder Theoretical Manual for the detailed description of the algorithm and the meaning of the parameters. If the FOLD operator is called with the second syntax, the airbag's plane is computed automatically.
