| 1. | From the Menu Bar, select Process > Results Mapper. |
| 2. | Select the Contour tab. |
| 3. | Select the parameter to display in the window Type of value: |
| • | Thickness |
| • | Plastic strain (select the integration point by clicking |
| • | Stress tensor (select the integration point by clicking |
| 4. | Click |
| 1. | Enter a value in the field, Min value:. |
| 2. | Enter a value in the field, Max value:. |
| 3. | Click |
| 4. | Click |
Click
to clear the display in the graphic window.
Click
to increase or decrease the number of colors.
