| 1. | Enter a first root file name in the Output file name window. |
or
Click Browse to select a directory and an already existing file.
| 2. | Select the shell formulation type: |
| • | Old formulation (RADIOSS version 3.1) |
| • | New formulation (RADIOSS version 4.1) — recommended. |
| 3. | Select the output value. |
| 4. | Select the number of integration points for the parts by clicking . |
| 5. | Click Write to save the files, Y000 and Y111. |
A second Browse window appears.
| 6. | Set a second root name for the D00 and D11. |
This second root name must be different from the first one. A geometric output is usually requested if IGTYP is greater than 0 (see the flag IGTYP in the card /IOFLAG in the D00 file).
