The file, $MCRASHDIR/themes/mcrash1rc defines the HyperCrash window parameters.
Keyword{
Arguments 1
Arguments 2
Arguments n
The comment lines start with the # character.
# pixmap_path "<dir 1>:<dir 2>:<dir 3>:..." # # include "rc-file" # # style <name> [= <name>] # { # <option> # } # # widget <widget_set> style <style_name> # widget_class <widget_class_set> style <style_name>
pixmap_path "."
style "defaultfont" { font = "-adobe-helvetica-medium-r-normal--*-120-*-*-*-*-*-*,*" }
# common default
style "window" { bg[NORMAL] = { 0.2, 0.2, 0.4 } }
style "toggle_button" = "default" { bg[ACTIVE] = { 1.0, 1.0, 0 } font = "-Adobe-Helvetica-Medium-R-Normal--12-120-75-75-P-67-ISO8859-1" }
#widget_class "GtkWindow" style "window" widget_class "*GtkCheckButton*" style "toggle_button" widget_class "*GtkRadioButton*" style "toggle_button" #widget_class "*Gtk*Pan*" style "window"
# possible priorities are (in ascending order): # lowest # gtk (used by gtk for internal class bindings) # application (for hard coded bindings on application basis) # rc (used implicitel by rc files) # highest |
