| 1. | From the Menu Bar, select LoadCase > Boundary Condition > Create. |
| 2. | Enter a name in the Boundary condition creation field and validate with Ok. |
| 3. | Make a selection from the radio buttons: Added, Removed or See |
| 4. | In the Selections sub-window, select nodes using the different tools from the Selection folder. |
Button |
Behavior |
pick nodes in the graphic window, and then press Enter, right-click the mouse button or select Yes or Cancel in the Dialog menu bar. |
add/remove object by ellipse selection. |
add nodes by box selection (the default box is rectangular — use the SHIFT key to define a polygon box). |
remove nodes by box selection (the default box is rectangular — use the SHIFT key to define a polygon box). |
pick parts in the graphic window, and then press Enter, right-click the mouse button or select Yes or Cancel in the Dialog menu bar. |
add parts by box selection (the default box is rectangular — use the SHIFT key to define a polygon box). |
remove parts by box selection (the default box is rectangular — use the SHIFT key to define a polygon box). |
add the parts selected in the tree. |
remove the parts selected in the tree. |
| 5. | In the Reference Axis sub-window, a skew frame can be defined for the boundary condition: |
| • | Click the Reference Axis folder. |
| • | Define the reference axis using the different tools from the Reference Axis folder. |
| 6. | Make a selection from the radio buttons: Global, Moving Local or Fixed Local. |
| 7. | Click Tx and/or Ty and/or Tz to fix the translation degrees of freedom (selected). Click it once more to release the degree of freedom (not selected). |
| 8. | Click Rx and/or Ry and/or Rz to fix the rotation degrees of freedom (selected). Click it once more to release the degree of freedom (not selected). |
| 9. | Click Save to save the created boundary condition; or |
Click Cancel to cancel the boundary condition creation
| 10. | Click Close to close the menu. |
