| 1. | From the Menu Bar, select Loadcase > Boundary Condition > Modify. |
| 2. | Select boundary conditions using one of the following methods: |
Button |
Behavior |
select all the boundary conditions. |
pick boundary conditions in list. When finished, answer the question in the Dialog menu bar with Yes or Cancel. |
select boundary conditions by box (use the SHIFT key to use a polygon box). |
pick parts in the graphic window to select all the boundary conditions applied to those parts. When finished, answer the question in the Dialog menu bar with Yes or Cancel. |
select parts by box (use the SHIFT key to use a polygon box) to select all boundary conditions applied to those parts. |
Click the imposed displacement line in the listing window to select it. Several boundary conditions of this list can be selected using the SHIFT, CTRL, or SHIFT+CTRL keys. |
| 3. | Select only one boundary condition and click |
| • | Change the boundary condition name. |
| • | Select or deselect nodes or parts (see Node and part selection). |
| • | Modify the skew frame (see Reference axis). |
| • | Modify the boundary condition direction (see Direction setting). |
| 4. | Click |
| 5. | Click Save to save the modified boundary condition; or |
Click Cancel to cancel the boundary condition modification.
| 6. | Click Close to close the menu. |
