From the Menu Bar, select Mesh Editing > Constrained menu option, use the Generalized Weld option to create, delete, edit, or cross reference a Spotweld.
In the Generalized Weld panel, right-click to access the context menu, and make a selection from the available choices.
| Note: | Selected spotwelds may be turned ON or OFF in the display through the Model Browser. |
All spotwelds can be turned ON or OFF using the Display Graphic objects or Mask all graphic objects icon on the main toolbar.
| 1. | When you select Create New from the context menu, select the appropriate card panel. |
| 2. | Click to edit fields and right-click in the applicable fields for more options. |
| 3. | Click Save or Cancel when you are finished creating the card. |
