1. | From the Menu Bar, select Model > Material. |
2. | Below are the available options to sort the material list: |
• | Click to sort the material list by number. |
• | Click to sort the material list by name. |
• | Click to sort the material list by type. |
• | Click to sort the material list by status. |
3. | Under Choose Material Law, select a material. |
4. | Click and pick parts in the graphic window to select or deselect them. |
5. | Click to add or remove the parts from the tree selection. |
6. | Enter the different values in the fields for the material: |
• | Set the value or the material name. |
• | Click the toggle button to switch options ON or OFF. |
• | Click the button for the function to set or modify a function. |
• | Set the number for the function needed and click Ok. |
7. | Optional: for materials that include curves, click to view the curve. |
A Plot Window opens.
8. | Click to save this material (as a RADIOSS input deck file): |
• | In the new sub-window, select the directory to save the material to (left area part). |
• | Enter the name of the material to save. |
• | Select OK to save the material or Cancel to cancel the save. |
9. | Click Save to save the material creation; or |
Click Cancel to cancel the material creation.
10. | Click Close to close the menu. |
