| 1. | From the Menu Bar, select Data History > Assembly > Modify. |
or
If the Data History panel is open, select Assembly > Modify from the pull-down menu.
It is possible to directly delete a time history assembly group or, within a group, to delete a time history assembly.
Delete a time history assembly group
| 1. | Click the time history assembly group to be deleted. |
| 2. | Click . |
| 3. | Answer the question in the Dialog menu bar with Yes or Cancel. |
Delete a time history assembly in a group
| 1. | Click the time history assembly group from which a time history assembly is to be deleted. |
| 2. | Click to display the time history assembly(ies) in the graphic window. |
| 3. | In the time history assembly list, select the assembly list to be deleted. |
| 4. | Click . |
| 5. | Answer the question in the Dialog menu bar with Yes or Cancel. |
| 6. | Click Close to close the menu. |
