Use the Pressure Load option from the LoadCase menu to create, delete, edit, rename, or cross reference a pressure load card (/PLOAD).
In the Pressure Load panel, right-click to access the context menu, and make a selection from the choices of Review, Create New, Delete, Rename, and Cross Reference.
| Note: | Selected pressure loads may be turned ON or OFF in the display through the Model Browser. |
All pressure loads can be turned ON or OFF using the Display Graphic objects or Mask all graphic objects icon on the main toolbar.
Create a new pressure load:
| 1. | When you select Create New from the context menu, the PLOAD card panel appears. |
| 2. | Click to edit fields and right-click in applicable fields for more options. |
| 3. | Click on the arrow next to Sensor identifier and/or Support to expand the sub-menus and make selections from these menus as applicable |
| 4. | Click Save or Cancel when you are finished creating the card. |
