»Click here to display Table of Contents« HyperCrash > HyperCrash User's Guide > LoadCase:
If you are working in the LS-DYNA profile, from the Menu Bar, select LoadCase > Rigid Wall. Right-click in the Rigid Wall panel to access boundary conditions options. Otherwise, the following instructions will guide you in each process.
Create a rigid wall
Modify or delete a rigid wall
