It is possible to define more types for the monitored volumes using one of the six basic types (AREA, PRES, GAS, AIRBAG, COMMU, FVMBAG).
For example, one might want to be able to create tires without entering the same values each time.
To do so, the configuration file, monivol_types.cfg has been created for the monitored volumes, containing default types and values.
Please check the HyperCrash Description Manual for information on how to customize the monitored volume menu.
