| 1. | From the Menu Bar, select Data History > Element > Modify. |
or
If the Data History panel is open, select Element > Modify from the pull-down menu.
It is possible to directly delete a time history element group or, within a group, to delete a time history element.
Delete a time history element group
| 1. | Click the time history element group to be deleted. |
| 2. | Click . |
| 3. | Answer the question in the Dialog menu bar with Yes or Cancel. |
Delete a time history element in a group
| 1. | Click the time history element group from which a time history element is to be deleted. |
| 2. | Click to display the time history element(s) in the graphic window. |
| 3. | In the time history element list, select the time history element to be deleted. |
| 4. | Click . |
| 5. | Answer the question in the Dialog menu bar with Yes or Cancel. |
| 6. | Click Close to close the menu. |
