Location: From the Menu Bar, select Mesh Editing > Offset Shells.
The Offset Shells option lets you create and modify elements by offsetting from a mesh of plate or shell elements. The element normals provide directional information.
To learn more about the concept of Offset Shells, see the section on Shell Offset in the Elem Offset Panel in the HyperMesh User's Guide.
