| 1. | From the Menu Bar, select the Options > Display. |
A Display tab appears.
| 2. | In the Display selection portion, select from the following: |
Button |
Behavior |
pick part(s) in the graphic window. When finished, answer the question in the Dialog menu bar with Yes or Cancel (bottom-right of the screen). |
pick boxed parts in the graphic window. |
include the part(s) selected in the tree |
delete the previous selection, if needed |
| 3. | In the Color portion of the window, the part color can be modified: |
| • | Use the chromatic circle: move the cursor to select the desired color in the chromatic circle. |
| • | Move the cursors to select values from the following: Hue, Saturation, Red, Green, or Blue. |
| • | Set the values for each color. |
| • | The brightness level can be adjusted with the vertical selection box (right side) or with the Value cursor. |
| • | Click Part selection to modify the color of the selected part(s). |
