| 1. | From the Menu Bar, select the Options > Display. |
A Display tab appears.
| 2. | In the Part display portion, select from the following: |
Button |
Behavior |
view display by parts |
display the selected part(s) with points |
display the selected part(s) with contours |
display the selected part(s) with lines |
display the selected part(s) with polygons |
display the selected part(s) with polygons and contours |
display the selected part(s) with polygons and lines |
cancel the part display modifications |
| Note: | The display type will be modified if the display type modification on the toolbar is used. |
