| 1. | From the Menu Bar, select Data History > Assembly > Create. |
or
If the Data History panel is open, select Assembly > Create from the pull-down menu.
| 2. | Enter a name in the Assembly for time history field and validate with Ok. |
| 3. | Click to add the selected subsets in the tree, |
or
Click
to add all subsets in the tree.
| 4. | Set an assembly ID in the Assembly Id field and click Ok. |
| 5. | Click Save to save the time history assembly; or |
Click Cancel to cancel the time history assemblies creation.
| 7. | Click Close to close the menu. |
